what's the width of my wheels?
Does anyone know the width of the front and rear wheels on my 06 997, they are OEM 19" Carrera S wheels on a non S Carrera. Thanks for your help.
Bob
Bob
Thanks Dan, I'm looking at Carrera Sport wheels, I'm assuming I should stay with the same width as OEM.
Poseur
Originally Posted by jhbrennan
The Sport wheels are 8.5 (F) and 11.5 (R) - since they're listed as an option, I wouldn't think the extra .5 will cause any problems.
(Those are the XRR option wheels)...rear tires go up from 295s to 305s.
Dan
Newbies Hospitality Director
Bob - just make sure you ge thte correct offset for your car. Now that the wide body C4S has come out, the wheel offset for the wide body will NOT fit correctly on a narrow body.
I get it, thanks guys.
My local P-dealer had a used C2S in their inventory, that had one rear wheel from a C4S. It stuck out just a little bit from under the fender. Though it was a huge difference from the other side. Look like the hole rear end of the car was out of whack.
I normally run XRR's with rear 305's but just fitted up Michelin Sport Cup semi-slicks (305 at rear) on a set of "lobsters" (centres painted in black semi-gloss) .........Porsche mistakenly gave me the C4 rears i.e. ET51 offset ............sits at the very edge of the body .......... VERY AGGRESSIVE LOOK .......but will swap back to the ET67 offset they should've supplied & use a 7mm spacer
