Fricking Scratch!
Fricking Scratch!
Damn it, damn it, damn it, damn it!
I scratched it! I was putting my drycleaning in the car adn caught a hanger on the top side of the door sill. It is 2 1/2 inches long and fairly deep.
I made things worse in a panic by trying to fix with porsche touch up paint. I smudged the paint but filled in the scratch. I am a total bafoon with fixing things so what do i do?
I have no dealer in my area (Spokane, WA). Who do I call?
Try to remove the blob with some alcohol or gasoline. A detailer or body shop can offer some help if they are nice. Then, use toothpick to apply new touch up paint. Get as little paint on the toothpick as possible and apply in layers with drying time between each coat.
littlebigfish....first off don't panic about your paint touch up...that's easy to fix...You've obviously got touch up paint which is the main thing....I suggest you try this product
http://www.langka.com/ (plenty of how to videos on this site)
It makes touching up easier, and look better.
The product ships with a blob remover (which will get rid of the excess that you say is now smudged)
In the meantime the other way to remove the excess and improve the appearance is to get some scratch X by meguiars (available at walmart, target, autozone etc) great little product at getting scratches out by hand....make sure area is perfectly clean (use isoprop alcohol to make sure) apply with a foam applicator, apply about a dime size and use firm hand pressure (10 to 15 lbs...yeah that was 10-15 lbs) keep rubbing for @ 2 mins or until product has consistency/look of vaseline. You may need to apply 5 to 6 times. First off, this will get rid of the excess paint, and it will also significantly reduce the scratch...You can't do any damage to the paint as the product uses diminishing abrasives (start off abrasive and break down to become a polish) the world's come a long way since rubbing compounds.
Here's a video link on how to use scratch x
www.showcargarage.com
and here's a great article on touch ups......(which often look better when you do it rather than a bodyshop, because they don't have time to do it this way, and would rather just respray!!)
http://www.guidetodetailing.com/arti...p?articleId=27
fyi, the langka kit pretty much does the exact same thing as the article above, just in a more user friendly way
If you don't want to do any of the above, suggest you call a paintless dent removal guy and ask him to recommend a mobile touch up outfit....these guys can airbrush scratches out at your home with stellar results (dealers often use them when they have leased cars returned that need a little tlc but not a bumper spray etc, or accidently f%$k up your car when the techs keys attached to his belt scrape along your paint!!)
Good luck, and let us know how it turns out...
Jason
Jason
littlebigfish: The product jfraser suggested is cool - langka. Or, you may want to use Touchup Magic. EBoth very helpful products and either works very well for those of us less adept at touchup. I would say they are a must for amateurs (such as I).
Ben, the bottom of the scratch was white before i blobbed on the touch up paint. From your description in your link, although i havent done the water test, the scratch seems like a category 2.
Thank you for the detailed suggestions. I need to think about DIY vs. outsourcing the job. I have a friend in the area who is a p-car fanatic and he recommended an outfit in town that would do a good job. I'm leaning this way but a part of me says DIY.
My recommendation is to go with your friend's suggestion and take it to professionals who have done this repeatedly and successfully. I think you would be putting too much pressure on yourself if you were to attempt to DIY, especially if you've never done touch-up work before. It does take experience to do it right - you'll rarely do it like a pro on your very first try. And you certainly don't want to compound your grief if it ends up being short of expectations.
Take it to the pros and take a load off your mind. ... Good luck!
It sucks, but scratches happen. Try as I may, I managed to get one on my back bumper that I can't place. I didn't hit anything and noticed it while detailing, so I wonder if I caused. I can't imagine how since I use two buckets, two mits, and make single downward strokes when cleaning. I also rinse thoroughly and even use a boars hair brush (VERY lightly with the tips in single strokes then rinse) on the bottom panels to clear the heavier debris before going to a mit.
I also picked up about 5 rock chips above the stoneguard line today during a driving event. It suicks, but they happen.
I'll try out some of the tips here.
What is the best way to get scratches removed from the rear bumperette? It is very slight as I bumped lightly into another bumper while parallel parking (yes I admit it!!!). Would Langka work on that kind of scratch? Or, is there something else since the bumper is plastic?
https://rennlist.com/forums/997-forum/231246-are-paint-swirl-lines-inevitable.html
I have already 1. hit a bird ( on the hood...saved by clear bra). 2. Run over unknown object between lanes 3. Got a rock chip in my windshield.... of course it is on the drivers side. I'll still keep on driving
