PCM Setting (Do it yourself or dealer?)
![Red face](https://rennlist.com/forums/images/icons/icon11.gif)
I finally got a chance to read the owners book and I wanted to change some settings such as auto door lock, day run lights, orientation lights etc. According to the owners book I can do this by accessing specific menus. I can't find the menus and after wasting lots of time today, I realized that maybe these are only accessable by the dealer. Can anyone give a little insight? BTW,
has anyone set the homelink with a rolling code opener? Gees, I couldn't get that to work either. My Japanese cars were simple to program...
Thanks!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Thanks!
Not in MA anymore
Do you have the Sports Crono? I think you need that to be able to do this yourself.
Matt
Matt
yes, I do have sport chrono
Thanks!
Thanks!
If you have any problems, let me know and I'll go back to my car and confirm this is the correct procedure.
Also, the Homelink does work with rolling code opener. Just remember that after you program the homelink button on the car you then have 30 seconds or so to link it with the contol panel for your garage door opener. You need to see your garage door opener manual on how to do this since there are different procedures among the different brands.
I hope this helps.
Thanks guys, I will try this again and I'm printing the homelink stuff right now.
Mine didn't display the "individual memory" menu. Is it my option package that won't allow the display oif that menu? Any help is appreciated.
Originally Posted by MJones
With the key in ignition
Ignition ON
Go:
Main Menu > Press Set
Individual Memory will appear
Ignition ON
Go:
PCM System
Main Display
I am not sure how to scroll between them. Maybe the Individual Memory is one level down.
mine is the same as ohsixx, only two PSM and Main display
There must be some piece of optional equipment that we do not have. Guess I can live with it. Gotta go drive now.
The ability to set these features without having the dealer do it is only available if you have the Sport Chrono option. Pretty clear instructions with pictures in the PCM manual. I believe the topic is in the Individual Memory section of the PCM Manual, not the Owner's Manual.
Originally Posted by ohsixx
There must be some piece of optional equipment that we do not have. Guess I can live with it. Gotta go drive now. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The Sports Chrono gives you "Analog and digital chronometer, sport button in the center console and display in the PCM, also adds ability to adjust lighting, wipers, AC and door locking to suit personal preference."
So if you have it, like Bob in NY, you should have the ability to do this. The fact that you only show PCM system and Main Display (Individual Memory and Steering wheel should be underneath), makes me think that you may not have the correct version of the PCM software. There was a thread here a while back regarding how to check which version you have (I think its in the manual as well). You may need to have the dealer update the software.
Does anyone else have another version?
EDIT: I do have the sport button on the center console.
