PASM Question
Old Apr 7, 2006 | 01:53 PM
Zookie's Avatar
Zookie
Default PASM Question
Now i know if i get a 997 with PASM, i cant lower the car with Coilovers. Can i use a Set of Lowering Springs, to lower the car? Did the 996 come with PASM? Thanks and please LMK
Old Apr 7, 2006 | 03:44 PM
ONEOFEW's Avatar
ONEOFEW
I am not sure if fully understand your questions about the 996
There are coil over systems available for 997, one that I know is made by H&R 29239-5, however it will delete your PASM.
There are also a variety of lowering springs aout there as well "Eibach, TechArt,"
Do a search on this board for "lowering springs" there is allot of info
Old Apr 7, 2006 | 03:46 PM
Zookie's Avatar
Zookie
Lol i dot think you understodd what i said.
997 with PASM, can you use Lowering Spring, or will i have to Delete the PASM? I know you cant use Coilover, i already mentioned that.
Old Apr 7, 2006 | 04:03 PM
MJones's Avatar
MJones
The new 997 GT3 has coilovers and PASM
Old Apr 7, 2006 | 04:15 PM
ONEOFEW's Avatar
ONEOFEW
PASM is connected to your dampeners" Shocks"
Lowering springs will just lower the car, PASM will still function.
I am not too sure about the 996, they may have had something similar called psm
Old Apr 7, 2006 | 04:27 PM
Bob Rouleau's Avatar
Bob Rouleau
Still plays with cars.
PASM was introduced on the 997 and the 987 Boxster. It does not exist on the 996 or earlier Boxster. PSM is a very different thing, it is a stability management system.
Rgds,
Old Apr 8, 2006 | 07:01 PM
reubstarr's Avatar
reubstarr
Yes they do make lowering springs for 997 with pasm. Gemballa have them and they allow pasm to work. Yes they are different from non pasm springs.
