Any 997 owners been on track with their cars?
#31
Originally Posted by mooty
depends on how much camber you have. up to 1.5 is fine. inside will wear out more, but not much. at 2 deg, you really chew up the tires fast.
it's the toe you are more concerned with. zero toe or tow out helps turn in, but you may feel the car following road grooves a lot more. i dont really mind on mine.
also, if you do max caster, the steering effort increases ever so slightly, i like it.
#32
GT3 player par excellence
Originally Posted by crispenigl
what is a max caster?
draw a line from center of wheel vertically down to the ground. the pivot the front wheel forward. the angle b/n the pivoted front wheel and the vertical line you just drwan is called caster.
or look at a big harley with long front fork and wheel slanted all the way out front and copared that to the "normal" looking ducatti's. the forward slanted harley has MORE caster than the ducatti's.
i know this explanation is most likely beyond poor. someone help me out here.
#33
Newbies Hospitality Director
Seriously, I have a vague idea but not enough to be able to explain it well. Sorry!
