06 PDE note
Old Feb 7, 2006 | 03:51 PM
MJones's Avatar
MJones
Default 06 PDE note
The 997 will ride on 18" wheels
Reason:
18" wheels for a few reasons including cost, improved wear and handling characteristics at the limits. Overall the 18" seem to be more forgiving and really do not give up a noticeable amount of performance over the 19".
I look forward to seeing the differance between 18" & 19" and if the tires hold up better, I may be looking for a set of 18" wheels for the fun driving. I just but the 3rd set of fronts on my car in 15,000 mi
Old Feb 7, 2006 | 04:31 PM
Deanski's Avatar
Deanski
Reason:
OUCH! 3rd set?? Oh great... My C2S has the 19's on order. Oh boy, better get stock in Michellin.
Regards,
Deanski
Old Feb 7, 2006 | 04:43 PM
MJones's Avatar
MJones
Don't worry under normal driving the 19" tires will last just fine...
Under Track/AutoX hard driving the outer edge will take a "beating" and roll off way before the rest of the tire. I recently had an alignment and put as much negative camber as the car in it's stock form would allow....-40"...better than the -20" that it had but I was hoping for more...
maybe I should just drive in a straight line
Old Feb 7, 2006 | 04:50 PM
Deanski's Avatar
Deanski
OK I won't worry... YET!
Nah, if you wanted to go straight, you'd maybe bought a Z06 right?
Regards,
Deanski
Old Feb 7, 2006 | 11:23 PM
mooty's Avatar
mooty
GT3 player par excellence
my lowly cayman came with 19" ps2. i put 400 miles on laguna seca and 3000 total miles. the tires worn evenly. you just need to adj pressure for track use.
that said, i have 18" coming for track use. tire are cheaper and lighter. more r compound to choose from.
why i have 19" on the car then. i didn't want to wait. i wnated to drive the thing home THAT day.
Old Feb 10, 2006 | 03:55 PM
NoSubEDU's Avatar
NoSubEDU
I've actually been able to go a good 11k miles on my rears and still have plenty to go....WEIRD!
