Installing colored wheel crests
Old Jan 4, 2006 | 12:53 PM
fuenfer's Avatar
fuenfer
Default Installing colored wheel crests
I ordered a set of colored wheel crests that should be arriving today. I would appreciate any guidance as to how to remove the old ones -- thanks in advance for any help.
Old Jan 4, 2006 | 01:09 PM
OCBen's Avatar
OCBen
The caps have two small diametrically opposite holes on the face. To remove the old ones, insert two small angled wrenches (hex or torx) inside, short end in. ... Align them after insertion so the short ends point together, roughly....and then pull!
Old Jan 4, 2006 | 02:32 PM
texas911's Avatar
texas911
What, no link Ben?
Old Jan 4, 2006 | 02:44 PM
OCBen's Avatar
OCBen
This time it was easier to type out the instructions than to do a search.
Old Jan 4, 2006 | 03:32 PM
Sands's Avatar
Sands
It is also easy to use two large paper clips. Bend one prong of one into a right angle, bend the other's prong into a right angle, insert one into each of the two holes, align them with ends pointing and PULL both together quickly. The old crest will pop right out.
Old Jan 4, 2006 | 03:36 PM
P997C2S's Avatar
P997C2S
When you install them align the point of the crest with the valve stem.
Old Jan 4, 2006 | 04:24 PM
996toomey's Avatar
996toomey
Good tip P997C2S.
Old Jan 4, 2006 | 06:16 PM
fuenfer's Avatar
fuenfer
Thanks for all the help folks! I can't wait to get home to install these things now ...
