Clear Bra: Maintainance
How to care for your clear bras? Can you wax them? Any special care? Is there any problems applying a clear bra if your car was treated with a telfon clear coat protectant? Any sense applying a clear bra to a leased car? Random thoughts. Thanks, patiently waiting for my C4S!
Yes, just wax them when you wax the rest of the car. I don't know that there is any special care for clear bras. I don't think they should be applied over any wax or polymer protectant, but I'm not sure about teflon because I've never seen teflon specifically mentioned. It would make sense to apply it on a leased car if you want to avoid chips showing while you have it. I know very little about leasing, but a lease contract might include a clause relating your final cost to their costs for necessary repairs to the car for resale. I plan to clear bra my car when it arrives, but don't know what I'd do if I leased the car and didn't plan to track it. I just touched up paint chips on my previous car which I bought used, but it was white, so easier to touch up and look right than the metallics are.
Some elements of the maintenance vary depending on what brand of clear bra you buy.
I own one car with a 3M bra and have been told to use wax or polish (Zaino for example) or whatever product I use to maintain the car in general. Because the 3M product has a clear coat on it, 3M says that you can use isopropyl alcohol on it to take out scratches.
My 911 has a Venture clear bra. I was told only to wax it (and to not use polishes like Zaino) and not use alcohol to take out scratches since it does not have a clear coat.
I would check with my installer and the manufacturer's web site for your particular brand.
By the way, I think that the Venture bra looks a lot nicer on the car. Much clearer and seems to stay nicer.
Pretend its not even on. Just wash and wax the whole car as usual. I've gone 3 years with 3M film on my daily car and its great. No problems at all. Hasn't turned yellow, or faded, or gotten cloudy.
My installer said to wax the film along with the car.
If you are using a wax that leaves a residue, you might wish to use some narrow low-tack tape on the film edges, because the wax tends to accumulate there in an annoyingly visible way.
Most installers fail to inform their customers of how wax lines are formed. Treat the film as a separate panel and wax the covered and uncovered portions separately. It's waxing over the seam and leaving it to bake in the sun that makes it difficult to remove later.
PREMIER PROTECTIVE FILMS (In Business since 1997) Proud member of Rennlist for 20+ years
ClearGuard Alpha G2 PPF vs Suntek Reaction: https://www.youtube.com/shorts/6hmSaMsHFkw
SatinGuard PPF
Spectra PhotoSync IRD - Highest heat blocking window film in industry
Ceramic Coatings
Checkout our Youtube Channel!
Premier's Youtube
B: 510-623-1308
42630 Christy St, Fremont, CA 94538
sales@premiermobilegroup.com
SatinGuard PPF
Ceramic Coatings
Premier's Youtube
B: 510-623-1308
Humbug: For cleaning a product I use with great results is Plexus Aircraft Plastic Cleaner. Developed for use in aviation for cleaning and protecting aircraft windshields and painted surfaces. Its quite simply the most effective product you can buy for cleaning, polishing and protecting all clear and colored plastics and painted surfaces. Link. (No afiliation)
Best!
Best!
Q-tip with some meguiars quick detailer removes the wax buildup along the edges very easily. My daily car is black so the edges are always visible if there is wax or dirt. Cleaning the edges in this way takes care of that problem.
