Wheel Spacers
Old Dec 10, 2005 | 10:03 AM
Anthony4579's Avatar
Anthony4579
Default Wheel Spacers
Has anyone added the Wheel Spacers to their 997/997S? I see it is also a factory option now. I would think that pushing the wheels out will be an improvement in the cars appearance, but would be interested to hear if there is a noticeable difference in the drive of the car.
Old Dec 10, 2005 | 11:33 AM
996toomey's Avatar
996toomey
Factory spacers are only 5mm so IMO hard to notice a visual or driving difference.
Old Dec 10, 2005 | 11:40 AM
JFScheck's Avatar
JFScheck
In my opinion, not worth the cost for a very small 5mm... I feel the 997 looks great as is!!!
Old Dec 10, 2005 | 11:45 AM
996toomey's Avatar
996toomey
I agree $500 for 5MM is a little pricey. I ordered my car with the Carrera Sports which are wider in the rear anyway so I am thinking that will give me a bit of a visual difference.
Old Dec 10, 2005 | 11:49 PM
JS's Avatar
JS
5mm is a very minimal difference.
Old Dec 11, 2005 | 01:13 AM
fuenfer's Avatar
fuenfer
I received a set of 5mm from Sunset Imports, but these appear to be for the 996. I'll post some pictures once I get the correct parts for the 997.
Old Dec 11, 2005 | 01:44 AM
lawjdc's Avatar
lawjdc
Actually the part number for the 5mm spacer is 996.361.605.90. You also need retaining screws (2 per wheel), part number 900.269.106.09, and extended lug bolts (5 per wheel), part number L996.361.980.00. I purchased my parts from Wheel Enhancement, and they are knowledgeable and give excellent service.
These fit perfectly on the back of a 2005 997S because I installed mine this morning. BTW, the only time you can tell the difference is when you have installed one side (I only did the rears) and then look at the other side without the spacer installed. You will notice that the wheel fills up the wheel well much better with the spacer.
I will put Michelin PS2's in the 305 size on the rear when my rears wear down another 4mm. They should fill out the rear fender wells just right.
Good luck with yours!
Old Dec 11, 2005 | 04:47 AM
20C4S's Avatar
20C4S
5mm is for fine tuning not for look. if u want the look u need anything above 10mm to see the difference. i know aftermarket company like Eibach has 7mm & 15mm for Porsche including bolts. 7mm is fine for the front but the 15mm for rear might be too much. local machine shop can make them as 12mm then they'd be perfect.
can u see the difference?
Old Dec 11, 2005 | 12:07 PM
JS's Avatar
JS
Arling, What size spacers on that 997?
Old Dec 11, 2005 | 06:16 PM
fuenfer's Avatar
fuenfer
Thanks for the insight, counselor. Out of curiosity, why did you decide to do only the rears? I'm planning on putting spacers on all four wheels.
And with respect to the part number, the Tequipment brochure my dealer gave me lists a part number for the spacers as 000, etc., not 996, etc. I'm going to double-check with the parts guys to before putting these on.
Old Dec 11, 2005 | 08:34 PM
tlsmithx's Avatar
tlsmithx
My understanding is that when you order spacers for a 997 the factory puts 5mm front and rear and on C4's they put 17mm on the rears and nothing on the fronts.
Old Dec 11, 2005 | 09:09 PM
997CarreraS's Avatar
997CarreraS
Registered User
I have a set of H and R 7mm Spacers and Bolts I bought for my 997C2S before I bought TechArt Formulas. These are a lot less money than the factory ones. If anyone wants them send me a private mail and we can work out a fair price.
Old Dec 11, 2005 | 11:45 PM
lawjdc's Avatar
lawjdc
I did the rear wheel spacers after lowering the car with H&R springs because the rear wheel track looked too narrow for the wheel wells. It became more noticeable when the car was lowered. The fronts look fine to me. I agree with the posts that say there is little or no performance difference, so I am just doing what looks visually correct to me. The part numbers I posted came off of the Porsche factory plastic bags the parts came in. The fit was perfect.
BTW, Park Place Porsche has a 5mm spacer kit on sale on its website for $350.00. It includes everything, and the part number for the kit is 000-044-500-09. So maybe it is the kit that has the 000 part number.
