Flat Repair
The forces on a tire at 130-150 mph are many many times more than at 60-80 mph. Since you don't drive on the autobahn ( with *sustained* speeds at 130mph or more) you can take the same risks 99.9% of all cars on American highways take: get it properly patched (if minimal damage allows patching).
A bigger concern would to make sure the LOW PROFILE tire is not RUINED but looks fine during repair because of a crummy mount/dismount machine and/or doofus using it.
Originally Posted by ultimate
...... it could safely be patched from the inside and it would lose 1 speed rating, so I have to keep it under , I think it is, 170 mph now. I think I am OK with that.
Honestly, I would feel nervous driving at that speed on any kind of tire.
This just happened to me. I had the tire warranty and the dealer said Porsche would not allow the tire to be repaired (only 900mi on tire, small puncture, Conti SC2). Our local driver's ed inspector will not pass your car for a DE with a repaired tire.
btw, as mentioned in another post, I strongly suggest that all without a spare put a tire plug kit and a pair of pliers in the trunk....if the hole is to big, the gunk will leak out, as will the air from the compressor. The plug kit along with the air compressor may at least get you to a dealer or home.
The DIY plugs are good enough to ride on (at sub-100mph speeds) for a while until it is convenient to get a proper repair/replacement
