Supercharged Carrera S 997
What is your opinion on Supercharging a Carrera S 997(either RUF or EvoMS).Is it safe for the engine?Has anyone installed a kit like that?Adding 150 H.P. is really tempting but i do have second thoughts regarding the drivability and the safety of the engine.....Thanks anyway!!!!!
The latest Excellence magazine has an article on the EvoMS supercharged 997.
it would be a blast to drive the article in excellence was a good article. low pressure in compaison to turbo charging.... I wonder how much different the interior of the motor and trans axels etc are from the true turbo porsche....
It is expensive 13,000. +/- then figure another 30,000. for everything Porsche wont cover WHEN something does go wrong because of warranty issues
Originally Posted by Findas
What is your opinion on Supercharging a Carrera S 997(either RUF or EvoMS).Is it safe for the engine?....Thanks anyway!!!!!
Would I do it? NO, mainly because of resale/depreciation and reliability issue. Further, if I want that kind of power, do it right by buying a Porsche TT. Just my 2cents.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
What reliability problems? Why would brakes have more stress? Coolant and oil temps are the same as a stock engine. You are destroying your engine alot faster using 0W-40 oil in hot climates than you do with a a properly installed SC system. I will make this a general statement: I assume you have no experience with supercharged engines.
If you want an investment that had no depreciation, buy a Treasury.
Here is a simple way of thinking about what the effects of supercharging are. Consider a naturally aspirated engine as one that only goes to half throttle. Think of the supercharged engine as one that will go to full throttle. All of the things which occur to your engine and drivetrain when going from half throttle to full throttle, occur with the supercharged engine. That includes coolant load, octane requirements, engine life, mechanical stress, exhaust flow, etc.
Aftermarket supercharger manufacturers are able to get away without much consideration of these factors, because they figure people only use the boosted mode for short bursts.
Michael
Michael
This is true for all street driven forced induction systems. There is minimal use of boost in Turbos and SC's. Your NA engine would be destroyed also if you ran at or near redline all day long. An engine cannot withstand either constant boost or redline for long.
My thoughts are this;
1st in all the articles I have ever read about Ruf they do tremendous testing of all their upgrades in power, so as to make it as dependable as the stock Porsche.
2nd, Ruf I believe does offer a warranty as they are considered a manufacture not an after market company.
3rd, Porsche does such testing of it's cars and they put the cars through a lot more abuse then we will ever do to our cars.
I have had the pleasure of driving a Ruf turbo and it was amazing(older turbo). I guess it would depend for me what I wanted and want you get for the money. What Ruf does to 911 Turbos is amazing and I am not sure I would want to do that to my Turbo but it is nice to know you can.
Regards,
Regards,
Michael
[QUOTE=1999Porsche911]What reliability problems? Why would brakes have more stress? Coolant and oil temps are the same as a stock engine. You are destroying your engine alot faster using 0W-40 oil in hot climates than you do with a a properly installed SC system. I will make this a general statement: I assume you have no experience with supercharged engines.
QUOTE]
Did I rub you the wrong way here my friend? What ever you say....I am not even going to discuss this with you on this subject. If you think I don't know my stuff, that's OK too. I don't need to proof anything to you. However, based on your response, I think it is YOU that don't understand how all this stuff works.
I would advise you to ease off on your words when you don't know what you are talking about or who you are talking to.
QUOTE]
Forced induction doesn't have to necessarily mean reduced engine life... provide it is tuned properly AND you pay a bit more attention to routine maintenance.
To 1999Porsche911's defense, he is probably just tired of the blanket statements that routinely get thrown out on this forum day after day about people worrying about the effects of supercharging... keep it friendly guys...
I thought the article was a negative statement. The added power comes only high in the rev range, and Excellence could not come close to duplicating the claimed hp on their own dyno test. The answer from the builder is that the engine needed to rev yet higher, perhaps over factory redline.
99/911 aside, I think it is a poorly considered option. Power developed high in the rev range isn't really important on the street.
Losing your warranty is.
Spending money on something with no resale value is a waste. Just wait and buy a turbo, if you want more power.
The only 996 I saw with an SC did have problems at the track. I was told the owner did have one trouble-free year.
You need to live near the installer, just in case it doesn't work properly forever. Who is going to solve a future dirvability issue for you? If you believe 99/911 it never happens. He must pray to the right god.
If you could get all that Hp with no longevity and reliablility issues, why does Porsche go thru all the trouble of using a different block, and innumerable engineering hours and dollars? They are stupid, right? A little shop in the middle of elsewhere is much smarter, right?
Sorry if I sound biased. Buying what you want is pretty effective. Trying to make something else into it is a tough proposition, unless you have a technician on retainer. AS
[QUOTE=Lotus350]
Stop by sometime and I'll show you that my SC'd 996 is running coolant temps that are more than 5% less than a stock 996 at all speeds and conditions. Also, you never responded on how the brakes are negatively effected by a supercharger.
QUOTE]
QUOTE]
