What Would You Recommend Re: PSE Install
The dealer received my check for the Porsche Sports Exhaust (PSE) kit it happened to have in stock, and is holding it for me. Because my car does not have Sport Chrono, a separate (on-off) switch for the center console is needed. The switch is not included in the PSE kit, has its own part number and needs to be ordered separately. Problem is the switch is on back-order from Germany with no ETA. Parts and Service managers both say they can install the PSE without the switch, so its always on, then install the switch later when it arrives. What do you think?
YoungTurk
'05 Carrera 911 (Arctic Silver/Black)
YoungTurk
I had the same situation. The back-ordered switch took about two weeks to arrive, and installing it took about fifteen minutes. I'd definitely proceed. However, the way it worked for me was that the sport exhaust was always off. The full resonance of the PSE wasn't available until the switch was installed. Maybe your dealer can wire it up differently.
Here is an interim - or perhaps even a permanent - solution to the lack of a switch for the PSE. Remove the rubber hose indicated by the red arrows from the Electric Change-over Valve in the engine compartment. With this hose removed, PSE is ON fulltime. Thanks to RC at RennTeam.
GT3 Track Junkie
1 Post
I had mine hooked up to the sport crono, and hated the exhaust. I pulled the rubber hose as shown above and now it's on all the time and man do I love that deep rumble!
Miserable Old Bastard
I would install it without connecting the electronics or vacuum hose - just PSE (default is open (loud)). See how you like it. Like many on the 996 board (including me with my prior 996), you may find that you don't need a switch at all. I don't think the installation cost to add the switch later will cost any more later than the incremental cost now, so no harm in waiting.
I just had my installed and I told them to leave off the switch. I love it. I am glad I did not get the switch installed. Of course, since I have a cab it may be easier for me to hear it all the time but I think it sounds great.
YoungTurk
Clearly, as you have inidcated, with no electrics or vacuum connections the PSE installation is ON full-time. All the rest of the installation is to satisfy legal requirements of sound laws in Europe.
Just trying to make some sense out of this.
If it were me I'd just use some other type of switch and place it inconspicuously under the dash where you can reach it. Just some type of toggle switch. I would want to be able to control its use.
Guys,is the PSE and the resulting increase in sound really worth $2400.00? I orderd the S and the sound is really nice, esp. compared to older 996 cars and the TT. This just seems like a lot of money for the increase in sound.
