Need Help Installing FVD Pedals....
Just got FVD pedals for my 997...no idea how to install it...I took off the factory rubber pedal covers and its a one peice plastic pedal under it....? Please help.... Thanks guys
Originally Posted by BD997
no!! can you imagine...I hope they dont expect me to drill thru the OEM plastic pedals
Carnewal's installed in my 997S (excuse the fish-eye lens)...
Super Moderator
Needs More Cowbell
Needs More Cowbell
(given the list of pending modifications, it would seem as though some small holes in the pedals are the least of the potential warranty issues)
Miserable Old Bastard
Looks like they install the same way as Carnewal pedals, which I recently installed. Brake/clutch - CAREFULLY mark where you want to drill holes; on the brake pedal (metal), a sharp drill bit will make it easier; bold pedals on, being sure to use aircraft-type nuts so they can't work loose. On the gas pedal, I drilled the upper portion, but at least thinking it would be tough to get the nut in behind the pedal at the bottom, I used a self-tapping screw for the bottom. Dead pedal (if you got it), basically just screws in over the existing rubber/plastic dead pedal. Keep Advil handy, as I was sore as hell after twisting around down there!
