3rd test drive of 997S
I've driven the 997S on three separate occasions. First, on the day it arrived at dealer showroom, then on two other occasions because two of my friends are buying one. I've had 02 C2, and currently have 04 GT3. On all three test drives the car felt like it had too much lateral movement in the back. even compared to my old 02 C2. I would like to buy a 997 as my daily use car but did not like this floaty/vague feeling. Is this the PASM feeling? I tried all possible settings. I'm interested in the M030 suspension I'm hearing about that drops car an additional 20mm over the sport setting in PASM. The dealership has no knowledge of this suspension. Does such a suspension exist? I was hoping some of you rennlisters have an answer. Does the standard 997 without PASM feel this way, I'm going to try to drive one. I liked everything else about the 997S FWIW.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Some of what you are feeling may be due to new tires, and them not being scrubbed-in, so to speak.. Maybe a shot in the dark, I dont know??
I have a 997 and will be putting springs to lower it. It does feel even more that way than the S with PASM....It is very nice on a long drive though as is....Just hate the look!
Yesterday I was driving an '05 997 with PASM at PDE at Barber Motorsports Park doing considerably higher speeds than you would on a public road thru various corners.
The new '05 cars are leaps and bounds ahead of the 996 version of which I came from. The PSM has a broader threshold as well.
No floaty vague feeling felt by me, just simply planted!
What on earth are you talking about?
And what kind of test drive circuit would allow you to acheive this conclusion?
Granted it is no GT3, but no slouch either... why would you want to switch anyway.
It drops the car -20mm with respect to the standard 997base suspension, so thats -10mm further than PASM since the PASM already drops -10mm with respect to the stadard 997 suspension (PASM is always -10mm, wether in sport mode or normal mode, ride height does not change with the 997's PASM setting, unlike the Cayenne's pneumatic PASM which is different).
Unfortunately, to this date, its only available RoW cars and there is no info on when it will be available in US or if it ever will be. Retrofit to a PASM 997 is not possible either.
Admit, I don't have GT3 experience.
I'm driving a 997 without the PASM. It is not floaty and indeeded planted like schvetkaaks and MJones are mentioning too. I'm still learning how to drive the car more to its limits, but I can tell you it is not floating or so. So, maybe it is indeed the PASM.
Drive one without PASM and tell us what your experience is.
The issue with what you're feeling is down to the kinematics of the rear suspension bushing. It has nothing to do with PASM and is present on all 997's. Essentially the bushings are too soft laterally.
What you may be feeling is almost as if a rear tire under increasing load begins to suddenly roll over - i.e the sidewall begins to flex and you feel the car shift sideways at the rear. It can also feel a little like tramlining at the rear. It's even more apparent when the car is in transition - slalom or S bends. It's not a big deal for most people and under constant load you won't feel it. Porsche should still fix it in the future (06? 07?) but who knows if they will...
In your position I would wait for the 997GT3 and not bother about an S.
Moogle: can't find one with -20 suspension.
Alan: thanks, I'll try to find out from european Porsche sites
MJones: I'm not replacing my GT3, the 997 will be an additional car. There is a great test drive circuit near my office where I have driven all my cars as well as all test drives. It is a good 5 miles in one direction, I go around it in both directions, it combines some highway, great off ramps, S turns, high speed sweeper, decreasing radius turn with some bumps, a lot of elevation changes thrown in - a lot of fun!
Carlos: thanks a lot, where can I find specs on the P17 you are talking about. I need this suspension before I buy any 997.
PV: thanks, I'll try to get a drive in a regular 997 without PASM. The P17 Carlos mentioned hopefully becomes available in the US.
Thanks to all
Thanks to all
P17 includes: shorter and firmer springs at front and rear (20 mm lower than standard 911 Carrera), new anti-roll bars with greater torsional strength, and firmer damper settings. Also included is a mechanically locking rear differential offering greater levels of traction on poor road surfaces or when exiting hairpin bends.
What is the problem ith a GT3 as a daily driver?
To me your wasting your money on the 997.
Get one or the other but not both.
Unless you need to be 4x4-ing why would you need the 997? Especially if you are going to want to lower it?
Buy an SUV instead and forget the 997.
RR: The 997 is not even close to being as low as a GT3. I need a rear seat. I hate driving trucks everyday. My wife drives the BMW 4.8is. I've had a Cayenne S for about 6 months and got rid of it - nothing but problems, see Cayenne forum. Should I waste my money on a BMW 6 series, Mercedes or something else, I'll rather get some sort of 997.
"I would like to buy a 997 as my daily use car"
I'm still not sure whether this is in ADDITION to your GT3 or INSTEAD of your GT3. It would make life a lot easier to answer if we knew...
