GSM Phone Module retrofit
There is a TSB for the install so the Tequipment real deal can't be far away.
p/n 997.044.900.071 Set, telephone module + you need an optical waveguide.
The module kit consists of:
Telephone module'Microphone
Wire harness
Antenna
misc screws nuts etc.
Time Units for install= 460 TU
You have to have the later PCM faceplate with the SIM drawer and SOS button.
If you have an early production vehicle without the later faceplate, and you want to install the GSM phone option, I would suggest that you write a letter to PCNA and see if they might accomodate you.
Wire harness
Antenna
