replacing the head unit
Old Oct 13, 2004 | 06:41 PM
twhite35's Avatar
twhite35
4th Gear
Default replacing the head unit
Does anyone have any information regarding replacing the stereo head unit with an aftermarket one? It looks impossible, as far as I can tell from pictures: no place to put it and no obvious way to even fabricate a custom dash piece to make it fit. Thanks, Tony
Old Oct 13, 2004 | 07:28 PM
Jared W.'s Avatar
Jared W.
I was wondering the same thing. I have a nice Mcintosh Car Audio system I took out of my M5 when I sold it, I was hoping to be able to put it in a 997....
Old Oct 13, 2004 | 08:36 PM
MJones's Avatar
MJones
The PCM screen et all is not just the audio head unit its the nav, trip computer, additional memory settings (S) not to mention the audio system and utilizes the MOST Bus. Mfg by Harmon/Becker
Old Oct 13, 2004 | 08:47 PM
Jared W.'s Avatar
Jared W.
Is the nav. an option or standard? I assume its an option, but I haven't yet seen a car without it. The "old" becker units from the 996 without nav were relatively easy to switch...
Old Oct 13, 2004 | 08:53 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Post
All MY03+ Porsches use a fiber optic connection between headunit, amp, cdchanger and finally back to headunit. The system is called MOST.
http://www.mostnet.de/index.php
If you replace the headunit (as there are currently NO aftermarket MOST devices, let alone headunits), then you will need to replace the amplifier and CDChanger as well.
Do a search for MOST in the 996, 996TT and Cayenne forums for more details and information.
Old Oct 13, 2004 | 08:59 PM
MJones's Avatar
MJones
The "Screen" is standard on all MY05 Carreras
Old Oct 13, 2004 | 09:09 PM
Jared W.'s Avatar
Jared W.
Yes, I know if you replace the head unit you must replace the whole system. I have cd player, amps, and even focal utopia speakers. But if the screen is standard, as it appears to be, then it becomes virtually impossible to replace the system without ruining the console. Too bad; I am fairly picky about my music, and although the Bose system in the 996 was one of the best stock systems I had heard, it still wasnt nearly as nice as the Mcintosh equipment with Focal speakers. The only stock system I have heard that approaches the quality aftermarket equipment can acheive is Bentley's system in the Continental GT (Alpine, I believe). Thanks very much for the information !
Old Oct 14, 2004 | 10:30 AM
MJones's Avatar
MJones
The BOSE® Surround Sound System in the '05 997 is much improved over the 996, check it out.
Lets face it, the only way we can fully appreciate a car audio system is when it is parked with the engine off.
When driving theres too much competition from external sources; engine sound, road noise and the beauty is lost.
Porsche cars are NOT vault quiet like luxo cruisers: ie:Bentley
Old Oct 14, 2004 | 08:56 PM
Paul Marangoni's Avatar
Paul Marangoni
The music is in the trunk! Forget about the radio and CD racket....
Old Oct 14, 2004 | 10:26 PM
twhite35's Avatar
twhite35
4th Gear
Default center tunnel
Does it look like there might be room in the center tunnel to put a headunit? I have seen that done on some european cars in the past.
