While You are In There" Front Bumper Removal
I'm planning on removing the front bumper for the first time since I purchased my 08 C2S and wanted to know what else I should look to inspect or replace while I'm there. The car has just over 100k miles on it.
Current thoughts...
1. Clean radiators (should I consider replacing them?)
2. Add mesh cover to reduce debris in the future
I appreciate any advice. Thanks!
Current thoughts...
dlascoskie (08-07-2024)
Low tone (lower) horn. Frunk release cable.
EDIT: posted a minute later after Hootsama - re: horn replacement. It would be so much easier with the bumper off, and the part costs about $40. There are many failures and my hand was pretty beat up when I did my .2 without removing. If you don't and it fails, you'll sound like a Clown Car at the worst possible moment.
BillB128 (08-07-2024)
tegraphile (08-08-2024)
If you're having trouble with HomeLink because you have a "rolling codes" opener, then replacing the HomeLink module is easier with the front bumper cover off (supposedly).
https://www.radiatorgrillstore.com/p...SACEgL44vD_BwE
RGS (08-08-2024)
2009 C2S 201K miles
The lower horn fails shortly after new. It looks like you have a good one... save your money. I would inspect all coolant connections for signs of leakage. I would only do cleaning between the radiator and condenser, straightening the condenser fins, and would add Wayne's emergency cable release. You don't need to have the bumper off for the cable release, but you will have everything exposed so why not.
BTW, that "radiator" you see through the grill is an AC condenser not a radiator. To replace it, you need to evacuate and reload the AC system using a special machine. Further attachment of the condenser to hoses is specialty work.
Peace
Bruce in Philly (now Atlanta)
Peace
Take a look at our radiator and condenser protection here for the 997.1 and other Porsche water cooled models!
https://www.radiatorgrillstore.com/p...ills-no-center
https://www.radiatorgrillstore.com/product-page/porsche-997-1-911-side-intake-grills-no-center
dlascoskie (08-15-2024)
I replaced the radiator in my BMW 1er two years ago and the two radiators in the Boxster last year this time. Unless it is leaking I wouldn't. I got bad ones out of the box. I'm not sure if the Mahle made in S Africa was bad on the BMW because it wasn't shipped correctly. It replaced a 3 year old S African Mahle that was leaking at the seam. Learned the expensive way to fill it with water then pressure test. After 3 and close three or four weeks without the car I ordered a double row CSF all aluminum. That was packaged the way something should be packaged.
Rock sent me two Mahle S Africa for the Boxster. They put the two in one box which was good. One had punched through the box so it went back. Replacement was sent in just factory box. It punched through. Had them send a Nissens. Again just the factory box and it was punched through. I called FCP and told them I wouldnt bother accepting the package unless the box was in a box. It was dropped shipped from Nissens in TX wrapped in cardboard. So far so good. I also replaced the four hoses when I did the radiator. The genuine Porsche parts are only about $12 each on line. I dont want to ever have to replace anything by those radiators again in any Porsche.
I cant stress enough, If the box isn't perfect send it back, and before you add $60 worth of coolant add $6 worth of water and pressure test the system to make sure the new radiator is good. I can change the radiator in my 1er in my sleep now after doing it 3 times in a month.
