Pulley or power steering pump whine?
2006 Carrera S, manual, 101700km.
Noticed a whine at idle but I'm not sure what it could be?
The water pump was changed last year. The tensioner pulley and belt 2 years ago.
One thing I noticed a few weeks ago was that the power steering liquid reservoir cap was a bit loose and had some fluid leak. Level seemed fine and hasn't leaked since I secured the cap.
Any hints?
Thanks!
Any hints?
Thanks!
2009 C2S 201K miles
Your gonna need a stethoscope. Harbor Freight has one for just a few bucks... it has an extender on it... start probing. you will find it right quick.
Peace
Bruce in Philly (now Atlanta)
https://www.harborfreight.com/mechan...ope-63691.html
Peace
jchapura (07-30-2024)
So all pulleys have been changed (except for the tensioner pulley, which was changed 2 years ago) and the whine remains. However, it's not as bad when I turn off the A/C but there's still a faint whine.
Also, the whine is not present when the engine is cold.
The belt was changed 2 years ago. One of the pulley's plastic (top one) was a bit worn out so I'm wondering if that caused the belt to be noisier and if so, if it's worth to change it? Could it be the tensioner?
Thanks!
Thanks!
