997.2 headlight (lens?)
Hi,
Did replaced one off the headlights, and now theres noticeable different between the new and old one. Don`t know the name, but is the part marked in the image below replaceable?
Thanks!
/Joachim
Thanks!
/Joachim
That’s called a “shroud” ( the chrome part ). I don’t believe those are found separately even aftermarket - i would be cautious of even removing it to be honest as the internals of the lens (glass part) have a lot of small fragile pieces for the leveling mechanism
That would probably be the whole projector assembly - weird that they’re different! Porsche def doesn’t sell those separately, you can reach out to lightwerkz to get aftermarket projectors but that’s a retrofit situation…
Sorry can’t be of more help
Definitely something that requires disassembly of the headlamp
If I were to go into my headlamps again I’d buy some new HID hardware from these guys.
https://www.theretrofitsource.com/pr...lenses-etching
https://www.theretrofitsource.com/pr...g/kits/shrouds
