PASM not showing
The module doesn't appear, so I cannot reset.
Petza; the left side wire won't reach across the car, so I don't see switching as a possibility.
Taking it in Tuesday.
Here is what I get in summation:
Short Test
Siemens Digital Motor Electronics SDI3
[img]green.jpg[/img]
No Faults Found
PDK Gear Selector - PDK GS
No Faults Found
Porsche Stability Management - PSM
No Faults Found
Tire Pressure Monitor - TPM
Current Fault Codes [img]red.jpg[/img] [img]redsmall.jpg[/img] 8003:
System disturbance [img]redsmall.jpg[/img] 8022:
Wheel electronics front right
Instrument cluster - 9x7
No Faults Found
Vehicle Electrical System
No Faults Found
Airbag - POSIP
Current Fault Codes [img]red.jpg[/img] [img]redsmall.jpg[/img] C152:
Communication PSM control unit (drive) [img]redsmall.jpg[/img] C150:
Control unit communication engine electronics (drive) [img]redsmall.jpg[/img] 8055:
AWS LIN no communication [img]redsmall.jpg[/img] 8012:
Voltage supply below lower limit
Advanced Weight System - AWS
No Faults Found
Steering Column Electronics
No Faults Found
Air Conditioning
Gateway
No Faults Found
Porsche Access System - PAS
No Faults Found
Front Body Module
No Faults Found
Rear Body Module
No Faults Found
Left Door Module
No Faults Found
Right Door Module
No Faults Found
All Wheel Drive Suspension Cornering Lights Convertible Top Targa Roof Park Assist Seat Memory Chronometer
Short Test
No Faults Found
No Faults Found
No Faults Found
No Faults Found
No Faults Found
Airbag - POSIP
No Faults Found
No Faults Found
Air Conditioning
Gateway
No Faults Found
No Faults Found
Front Body Module
No Faults Found
Rear Body Module
No Faults Found
Left Door Module
No Faults Found
Right Door Module
No Faults Found
At the dealer now.
They are also unable to access the module. The tech thinks it has been coded out. They will now try to see if it can be added back, which requires a call to the Vaterland.
I'll update as I hear more.
It's back and it works.
They reinstalled the factory module and re-coded.
Now, I'm trying to decide if I dare to try the DSC module again.
