High pitch squeal
High pitch squeal
Good day Gang,
First time Porsche owner. It drives wonderful but I hear this high pitch squeal sometimes when I’m stopped and idling. When I asked the dealer about it I was told, “the tech could not hear it”.
From my searching I’ve found, “It’s normal”, “It’s the hydraulic pump”, “It’s the drive belt tensioner”, “It’s a bearing”, etc.
Does this seem like something I should be worried about?
TIA,
James
09 997.2 C4S Cabriolet
71,000 miles
TIA,
James
71,000 miles
I’d bet its one of the drive belt pullies
Could be your AOS ... Mine squealed like a turkey on thanksgiving when it was going south and any squealing is not normal .
The two prior posts have identified the two possibilities - bearing on a pulley on the serpentine belt run or the AOS. If the AOS, the oil fill cap will be very difficult to remove with the engine running from the excessive vacuum.
cvalue13 (05-12-2024)
