Possible Coolant Leak - Where to Look? 997.2
2009 C2S 197K miles
Odd, my coolant level appears to have dropped a bit. It is below MIN, now it always would be just under that line but I noticed it is now a bit lower than normal. So where to look?
It is not the caps... I checked for whitish crusty stuff and nothing. I looked under the engine where that black plastic pipe connects... nothing... followed all the pipes underneath the engine... nothing. What gets me is I don't smell anything. Even back when my blue cap was leaking ever-so slightly, I could smell it in the garage.
My tank is new as of 15 months ago.
Ideas? I don't mind pulling a wheel or whatever.
Peace
Bruce in Philly (now Atlanta)
Peace
Great vid... thanx, tomorrow I will jack up the front and check those pipes. Excellent.
Dang, those UK cars really rot. The problems they have I have never seen here. He made a comment about how the mufflers were looking good as they were not split. Split ? Cripes, I never heard of a split can. Sheesh.
Peace
Peace
Peace
Peace
I pulled the front wheels... nope, no leaks I can see... again, I don't smell anything.
I added some 50/50 mix I had from when I flushed the system... so now I have it exactly at the MIN line... I know what will happen, over the summer, it will drop about 1/2 inch, which is maybe 1/2 quart. If its leaking, I should be able to smell it. Odd
Peace
Bruce in Philly
Peace
Bruce in Philly
Peace
Bruce in Philly
Peace
Bruce in Philly
Oil drops steadily and predictable. I change it every 5K... it always looks fine. Regarding the cross over... I don't know... I can see three pipes on each side... two coming from/to the radiators and on each side, there is a junction where the pipes go rearward. Nope, tight.. no residue... clean.
Peace
Peace
Bruce,
Have you tried putting your Uview refill device on to see if it holds vacuum? Or get a pressure tester from the auto parts store to see if it holds pressure.
Peace
UPDATE:
Just back from a 900 mile trip in 85F weather, and ... wait for it .... cold coolant level was just a tad, maybe 1mm ABOVE what it was when I took off for this trip. WTF?
I think I am dealing with the classic "measurement problem" where my observation is collapsing the wave function and I am within the probability curve of that wave.
Peace
Peace
I saw that video a few weeks ago and thought it a good idea to pull off the front underbody cover. Pulling it off revealed the same cross pipes as in the video. I have an ‘11 997.2S for comparison. The cross pipes are rigid aluminum, but there are a series of connections behind the underbody cover that are worthy of inspection. Several are the rubber hose with the pressed on metal flange that use an o-ring and spring clip to connect with the aluminum pipe. The connections at #’s 3 & 28 are worthy of inspection. Inspect both the left and right sides.
On the left side of the engine there is a plastic 90 degree elbow at the water pump area (pump to thermostat). It is common for a slow leak to develop there, the pipe would have white/pink residue on it. It may only leak when up to temp and while driving.
