control arm brake air ducts?
just did my control arms on my 2008 c4 cab, and how sweet it is!
the right front had an attached plastic duct for cooling;a black plastic molded panel which clips on the control arm in front of the brake to direct air to the disc. that was the only one. apparently some 997s have other ducts? i watched a video with a 997.2 S which seemed to have one on the right rear. anyone know if that's the only one on a 997.1 c4 cabriolet?
That is an OE part, and some differences between 997.1 and 997.2. Looks like the 997.1 part number is 997 331 485 00
I installed larger GT2 or GT3 versions as they install in the same place the same way - just direct more air to the brakes as they're larger. With my 12" wide rear wheels, had to notch the rear ones where the wheel runs. Don't have a good pic of the rears, but you get the idea.
Larger Front Brake Cooling scoops
