free plug inspection sought
Little oil fouling on #4, otherwise, nothing too bad there. A couple look like they're running in the lean side. I'd run a full bottle of Redline Fuel System cleaner in your next half tank of gas and a second full bottle in the next full tank after that. Might clean up your injector spray patterns a bit.
or… just use a slight dab of anti seize on the threads and reuse them. Otherwise a waste on money. I’ve been doing this for decades, including with all of my Porsches. Just don’t let the material get below the threads.
Graufuchs (04-04-2024)
50 some years ago we seldom used torque wrenches. Heads were iron, not aluminum. We were taught to tighten by feel.
But I've come to depend on torque wrenches for even the mundane. The problem for me is that if you change the coefficient of friction by adding modifying agents, how do you adjust the torque to compensate?
IMHO the cost of a new plug pales in comparison to a stripped head. That's me. I'll admit my bias. I generally don't pull plugs to inspect them. I did that to clean plugs on snowmobiles in the middle of nowhere if they fouled, but I was a youngster then!!!!
anewman (04-04-2024)
