Pulsating noise from brake pad and rotor combo
I am cross posting this here in case anyone has any experience with this noise. The car is a 997.2 Turbo with two piece rotors and a strange pulsing noise when running hawk pads…
https://rennlist.com/forums/997-turb...l#post19354653
This is what I would try before buying new rotors.
1. Gently remove the Pagid pad deposits on rotors with 240-400G sandpaper.
2. Wet the new pads and rub them together to take off any high spots.
3. Bed in the new pads.
BRN9121 (03-27-2024)
Clean both sides of rotors with red can (not green can) brake cleaner and a roloc pad on a drill, rebed the brakes doing a proper bedding procedure and you should be all set.
Thanks guys! Essex replied in the original post in case anyone is interested in reading their reply. We’re going to try a few different things including cleaning the rotors and bedding the pads. I’ll keep everyone posted on how things go when we figure it out.
