2005 C2S help
Hello-
I a have been considering buying a C2s, its a 2005 50K mikes. It has great service records from the dealer. Below is a little more:
*. Small IMS single row bearing ( no clutch work or IMS work done)
* No oil Leaks
* No smoke when cold start
* From what I see from exhaust no bore scoring (see video)
* Very clean car that runs good
Price is not great but it's a no accident, clean carafe, manual.
I would be upset if I bought and had to put a motor in it quickly
Thoughts
* No oil Leaks
Thoughts
Received 1,835 Likes
Hello-
* No oil Leaks
Thoughts
* No oil Leaks
Thoughts
It's easy to clean the soot off of a tail pipe(s) so that is no indication of whther the cylinders have scoring.
IMO Bore Scope Inspection and full PPI should be performed.----> DME report for Over Rev's, Cam Deviation Numbers as well as overall condition very important before handing over a payment![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Very good advise.
Borescope the engine.
Plan on doing the IMS bearing soon or immediately.
And might as well head off the AOS, water pump, thermostat, acc belt and pulleys that are required at 60K miles anyway.
The following 2 users liked this post by groovzilla:
ATX_Native (03-12-2024),
steveP911 (03-12-2024)
@norcalccd How do you know it's the easily replaced IMSB? Just engine serial number? Or something else?
I only mention it because the engine serial number method isn't always indicative of IMSB size, especially around model/production transitions. Since your date is fairly far from one of those transitions, it probably is small.
