I've read many threads discussing manual-trans shifter cable failures, replacements, and upgrades. What I have not found is if there are signs of impending failure. Will the cables show cracks, frays, separations, etc.? If yes, what part of the cable(s) are most prone?
Typically the cables snap or the plastic pivot pieces that attach to the shifter snap. It’s all damm plastic and will fail as they age. You won’t get a warning. They just go poof. I’d say after 10 years get them changed to new OEM plastic crap or get the numeric cables. All metal and won’t snap. Does add a bit more cabin noise and a bit more effort to shift. But in a good way. Reminded me of the top loader 4 speed in my old Mustang with a mr gasket shifter and metal shift rods. Yea I’m old.
The Function First metal cable ends are a 3rd option, and although I have a pair of numeric cables in the cabinet, probably what I'll do, just because it's a lot less work and I like the way my car shifts the way it is.
I didn't notice any symptoms before the cable ends decided to hop off their mount, happened while driving. Inspecting them is probably your best bet.
Here's some pictures I took last year when it happened. You can see there's a lot of play on the original ones, compared to the metal upgrade I installed. The red circle shows one of my cable ends that barely held on. I could snap it off with little to no effort. The other one had hopped off completely Another angle Metal end upgrade
Reason: typos
Thank you for the information. I am concerned as my (preowned) car has 100K+ on her and no evidence that the cables were replaced.
I am one of the few that likes the feel / throw of the factory shifter hardware, both Porsche and BMW. I strongly considered the FF upgrade for the shifter and their cable ends, but I will most probably replace with dealer cables. I may have remorse though... "while I was in there I should have upgraded!" Argh.
The visuals are very helpful. Thank you for taking the time to share.
