Plastic cowl rubber strip
I noticed on my 997.2 that the rubber strip on the plastic cover under the wipers is cracking. Not know what this is called, my efforts to search for it have not seen good results. What is the official name of this so I can look it up? TIA
https://www.ebay.com/itm/26612185755...gAAOSw5D1j4ohJ
They tend to discolor and can crack over time from the sun.
Replacements aren;t too expensive at about $150 - Not sure of the labor involved.
I think the little rubber edge is part of the larger cowl. Don't recall an option when I replaced mine. The little square bolt covers are extra.
The connectors for the washer spray nozzles were different so I had to do some surgery to mate them with my existing. 2005 997.1.
YRMV. Good luck.
YRMV. Good luck.
2009 C2S 195K miles
What is available is what is in the Porsche parts catalog. Pull down a copy for your car... I think it is illustration: 813-020. But be careful, as these cars may have options that require a slightly different part.
https://www.porsche.com/usa/accessor...artscatalogue/
Peace
Bruce in Philly (now Atlanta)
Peace
The following 3 users liked this post by Khloesdad:
Mine has had gaps forever. You may be able to get it to lay flat by adjusting the nuts.... pop off the little caps, one on each side and dick with the adjustment by loosening the nuts.
Peace
