ISUDAR PCM 3.0
I decided to remove the Isudar unit from my vehicle to see if my PCM would now work after putty it back in the car it worked. Feeling brave I reinstalled the Isudar unit and it now works. I will now button back up everything and hopefully it will continue to work. PV997 I will keep you updated on your issue. THANKS TO ALL!!!
David perkar (01-12-2024)
I also had the Isudar Carplay installed in the pcm 3.0 of my 997.2. I unfortunately found the picture quality very poor. Absolutely not sharp at all. I reconnected everything twice but no improvement. And you can't really do anything wrong with the installation. I contacted Isudar and they told me that the resolution of the screen of the pcm 3.0 was too low, so I did not get a sharp image as I would expect and want! Therefore, I returned the device and got my money back. I do use the great Tomtom nav again.
Hi everyone. I have installed the ISUDAR module in my 997.2 PCM 3.0 and when I connect it to the car the screen is black. I then removed the ISUDAR module and reinstated the cables as per original setup and when connected to the car I now also have a black screen. Can anyone provide me with any advice because I am stunpend. Any advice on what May be wrong would be greatly appreciated. Thanks.
Same here. I got it all installed and ran it for a few weeks but was not happy with the resolution, it made the car look dated. I switched to a full android headunit. Despite losing some of the features of PCM I am happier and it looks much more modern with a clean, hi res touchscreen.
After 5 months of usage I have no issues other than the occasional glitch. My screen resolution is good and maps are better than Google. Playing music from Amazon Prime is also good.
Step7 - I purchased the Mr 12 VOLT carplay adapter which has a circuit board installed in the main PCM as well. I actually messed up 3 times installing those *&^*+) ribbon cables. The first 3 attempts after installation of the board and putting it in the car I got a white screen only. I took the unit out and apart and VERY carefully reinstalled each cable and made sure that they were each fully seated and vertical in the connectors. If any cable is pitched just slightly off center or not inserted far enough - I could see how you might be getting a black screen.
