ISUDAR PCM 3.0
HAPPY NEW YEAR TO ALL : I just bought the Isudar unit for my 2009 997.2 with pcm 3.0. I am looking for any tips or tricks anyone may have as I am about to start my installation this weekend. PV997 had started a thread about this unit which I followed. His endorsement of the product convinced me to bite the bullet. He had mentioned he would post about the installation once completed with the install. I have been unable to find anything thus far. Any help would be appreciated. THANKS
My Isudar unit is out for delivery right now so I can’t be of any help, but eager to hear your impressions of the install and usage.
When I install mine I’m planning to try to tap into the stock mic in the harness as others have done in the NM and Mr12volt units. I expect this will work but have not seen any discussion of this approach on an ISUDAR unit.
There should be a plastic clip that holds the harness in. If you look for other 997.2 CarPlay install videos on YouTube there is a good overview of how to remove the harnesses.
I think this covers it well:
To tap into the oem mic I was planning to follow the steps on post 966 of this thread: https://rennlist.com/forums/panamera...-3-1-a-65.html
The circuit board supplied is black in color not the typical green as shown in the installation videos. It only has one connection for wifi on the black board. The board is RH8007 PCM 3.0 VER.1. I am assuming this is correct????
Hey Rod, I've had the Isudar unit for about five months now and no complaints considering the price compared to the others. One thing I have noticed is an odd quirk if I open the driver door without inserting the key. For some reason the relay on the Isudar board starts clicking probably due to misinterpreting the Canbus. It continues to do it unless I insert the key, turn it on, and then turn it off. I had been concerned this relay clicking would wear down the battery (if I hadn't noticed it and stopped it) but it hasn't happened so far. There may be a firmware/software upgrade that fixes this but I haven't bothered with it.
The only other thing is it's very tight if you have Sirius/XM and the standoffs have to be with ~2 mm range height to fit. I don't remember the exact height but bought an assortment on Amazon then stacked them to get the right spacing. The ones from Isudar didn't work (which to their credit they warned me of when I bought it).
Please post a follow up once you get it working, particularly if you notice the clicking issue. Also, there some specific settings on the head equalization unit that need to be adjusted to get good audio (I think I mentioned these in my earlier comment). This overcomes the HU's poor aux input tonal characteristics and is not an issue with the Isudar board itself.
Oops, the Isudar replacement cover does not fit my vehicle. After removing the 4 screws from the clamshell 2 screws front and 2 back, a cover did not come off instead a flat plate came off instead. My clamshell portion is a one piece metal shell. I am now trying to figure out how to cut a hole for the wires to fit so as not to pinch them and of course mitigating the pieces of metal that will surely get everywhere. Anyone else had this problem???
I was able to cut a hole in the top portion of my clamshell as I had explained in a previous post the replacement clam shell sent by Isudar is totally different than my original which is just a flat plate that separates the upper and lower clam shells. I did remove the module from the upper clamshell to mitigate metal filings and pieces. Plugging the unit in without installing in the console revealed a black screen. However a red light on the Isudar module flashes on and off every 3 seconds. Turning the ignition key to the 'run' position and holding the 'info' button down for 3 seconds or longer does not help. I removed the ribbon cables with the help of a jewelers head magnifiers replaced them no issues found. Tested again nothing. Can I START the car with the pcm plugged in to see if that helps or would that be a NO NO. Help anyone!! ps the pigtail off the main wiring is labeled pcm 3.1 not 3.0
