Strange Interior Rattle
I mentioned this is another thread - but as we all hate interior nuisance rattles, I thought I would start another thread on the topic!
I recently took delivery of a really clean and well sorted 2008 997.1 C4S. I bought it from a well known member of this site.
I am loving the car so far, and smile every time I see it in the garage, and am absolutely having a blast driving it. The PPI w/ bore inspection came out clean, and the cosmetic condition is even better in person.
Nuisance interior rattles are the bane of my car ownership existence, and I want to track down 2 I have noticed so far. One is coming from the passenger seat area but can not tell if it is the seat, the belt area, or the back seat - any advice would be appreciated, but it seems like it will be easy to rectify, but is also not overly annoying.
Secondly, I have a rather annoying interior ‘buzz’ that I get when driving on imperfect roads. The car has a passport radar detector that I am going to have removed, and I wonder if it is an unsecured wire the is resonating, but any other suggestions or thoughts would be appreciated. I have attached a very clear video of the rattle:
2009 C2S 194K miles
You may try shaking your car with your stereo... from another thread: https://rennlist.com/forums/997-foru...l#post18085340
Here are two videos I made of me shaking the cht out of the interior to find a buzz; in this vid, I use an audiophile CD with an inventory of tones at various frequencies: https://goo.gl/photos/zG3KY99vDUNefhBc8
If you have your phone connected to the stereo, you can use the tone generator here: https://www.szynalski.com/tone-generator/
From an older post of mine:
Bruce in Philly (now Atlanta)
2009 C2S 179K miles
If you can't find someone, there are some cool tricks I have used to find rattles. Play sine wave tones loudly on the stereo at various frequencies and the car will rattle/vibrate in sympathy with them. You will hone in on them right away... this exposes them like a light is shining. If you can hook your iphone or android to your stereo via the Aux port, you download free tone generator apps. Else, download some frequency sweeps... plenty out there on the 'net... copy them as MP3s to a USB stick and play them that way, or buy/burn an audiophile test CD that has either sweeps or tones. Do not use high frequencies, just the low end. High stuff can really hurt your ears and will not expose rattles and buzzes in the car.
Start low in the scale... say 50 HZ. Play loudly and anything near that will start vibrating or ringing. This works.
Porsche used to sell a CD that generated tones for finding rattles and buzzes.
More here: https://rennlist.com/forums/997-foru...l#post14202842
PeaceIf you can't find someone, there are some cool tricks I have used to find rattles. Play sine wave tones loudly on the stereo at various frequencies and the car will rattle/vibrate in sympathy with them. You will hone in on them right away... this exposes them like a light is shining. If you can hook your iphone or android to your stereo via the Aux port, you download free tone generator apps. Else, download some frequency sweeps... plenty out there on the 'net... copy them as MP3s to a USB stick and play them that way, or buy/burn an audiophile test CD that has either sweeps or tones. Do not use high frequencies, just the low end. High stuff can really hurt your ears and will not expose rattles and buzzes in the car.
This may or may not help. My seat rattle on my 991.2 was from the seat latch that moves it forward. Landed up sticking a piece of card in (and stopped using the latch). Had a buzzing from the drivers seatbelt too on my 997.1. Stripped the part on the B pillar and stuffed it with pieces of felt tape (harness tape). Was fiddly putting it all back together but problem solved.
When driving, watch the empty passenger side seat back and see if it's vibrating or bouncing at all. If so, that's usually caused by irregular wear on the rear tires, like cupping. Stock suspension settings on a 911 have quite a bit of camber. Also, get your head down to floor level behind the car and look at the inside 2"-3" of each rear tire to see if they're worn. If you have vibration from tire wear and eliminate the vibration, you'll eliminate the noise.
Also, quite a few of the wires behind the dashboard have foam around them so they don't make noise when they vibrate. If someone has been in there and moved their position or removed the foam to splice to a wire, they could now be making noise.
....or upgrade the exhaust and enjoy the song from the flat 6 which will also make the other noises disappear.
Thank you! These are great ideas, I have never thought of the audio frequency to find a rattle, great idea! I do not think my car has an AUX-in, but maybe I am not looking in the right place.
yes, I am noticing the passenger seat vibrating / moving at speed. The rear PASM struts were replaced very recently, could the rear end require an alignment? I have not checked the tire wear yet, but that’s my next course of action.
I had exactly the same on my 997.1 C2S cab with turbo style seats (with the hard cover). Used one velcro pad (the softest side of the velcro) at the bottom of each cut out for the lever in the cover. When not used, the lever falls over the sticky velcro pad, so you do not notice at all. This has significantly reduced the lever rattling.
