Storage and oil change procedure question
For those who are soon going to put their sled to bed, here is the most complete list I have seen:
https://www.porschenashua.com/porsch...-checklist.htm
Doing my first oil change on Friday.
Thanks for your input, really appreciated!
I don’t think that size fits. 997 plug size is 18mm. Try this one maybe?
DEEFILL M18 X 1.5 Oil Drain Plug Stainless Steel with Magnet Sump Drain Nut Bolt Red Copper Crush Washer Compatible with BMW Volvo Ram Dodge & Porsche
I also ordered these after Petza made mention of them ...
Hilitchi 180-Pcs Metric Dowty Bonded Seal Oil Washer Assortment Kit - 10-SIZE: M6 to M24 https://a.co/d/az8r6Ql
I looked at the pics of my car for comparison, but I run the MantisSport deep sump and it doesn't have the same recess the OEM sump plate does.
Aw I wish I would have seen this but yes mine stuck out a bit as well.
LucV (11-05-2023)
I am bumping this back up -
I do about 3k miles per year in my 997.1 C2 - I always change oil before winter storage (usually mid-October). Car sleeps with clean oil, but then usually I change the oil when I get the car out of storage too, for a total of two oil changes per year. I often see people mention that every six months is the longest they'd go between oil changes, but if the car is literally sitting with clean oil in it, is it dumb to do a second change in spring?
carguy999 (01-18-2024)
Ok! So for a "typical" 997 owner in areas where you get snow/winter and don't drive due to salt, I'm calling it now best practice - do an oil change before storage, and do your next oil change next time before storage.
The following 2 users liked this post by carguy999:
911grizzly (01-18-2024),
Petza914 (01-18-2024)
