Side mirrors do not remain adjusted
Anyone experience their side mirrors going out of adjustment, not at a result of bumps or anything, even a few minutes after adjustment. What is the solution? Thank you.
Maybe your motor might be done. Once you pop the mirror out, you can try testing the wire with a voltage meter.
https://www.sunsetporscheparts.com/o...or-99762404701
Evan2023 (10-16-2023)
If the mirror motor is toast, check out the thread below (see #8 response ) where I found the motor for GM cars work on the 997 as well.
https://rennlist.com/forums/997-foru...l#post18433624
MarkTro (10-16-2023)
or is it that the memory function got messed up?
