997.2 TCU Wiring
997.2 TCU Wiring
Good morning everyone.
A friend is working on a 997.1 to which he has fitted the engine and transmission of a 997.2.
The mechanical part is his responsibility as he has a workshop.
What I need is the wiring diagram of the TCU, as the original car did not have a PDK gearbox.
My friend has already installed the wiring from the TCU to the PDK actuator, but the part of the wiring from the TCU to the fuse box and gear selector has been cut!
So I'm asking you if you can provide me with the wiring diagram between the TCU and the rest of the electrical wiring. I assume there are the power and ground lines, the CANbus line and other signals.
I know it's not correct to ask in the first post, but only you can help me.
Best regards
Federico.
Best regards
Federico.
The following 2 users liked this post by veetwin:
964hans (10-09-2023),
federico.modina (10-09-2023)
Hi veetwin.
I am astonished. this is very usefull.
Would it be possible to share (if you have) the Wiring Diagrams for the 997.2 Turbo (2010-2012)
Regards
Hans
Regards
Hans
