Don't understand oil flushes
Up to you, but I've only seen 1 type of LM oil that gives numbers similar to driven. The others have higher copper, iron, and lead wear from main bearings. It's the green jug LM that seems to work well, but it also doesn't have any Moly in it so I don't understand why people use that and then buy a Moly additive separately when you can just use Driven and have it all in a homogeneous solution at the right levels and be done.
carguy999 (08-22-2023)
