Windshields
Windshields
Greetings. I have an 06 C2S, with a windscreen I’d like to replace (find the road rash annoying). Last I checked, the original was a $1,000 cnd just for the glass and that was before covid. Speedy Auto Glass has their own substitute and it’s $619 cnd, installed. I comes with all the same features and tinted, also, as the original. So, my question is, what will I be giving up if I go with the Speedy version? And, does it matter if it’s not the original?
Any and all thoughts appreciated,
Thanks,
John
Thanks,
John
If you want to save money, I'd at least go with the OEM, Saint Gobain Sekurit. The Genuine (with the Porsche logo) made by the same company will be the most expensive. The version you're talking about may be fine, but it may have more distortions in it. Nothing wrong with whatever direction you go, but for something you may only replace one time in your ownership, I'd rather pay a bit more and get what I know to be a quality part.
Petza914 (04-09-2023)
tegraphile (04-12-2023)
Just be aware that the installation of the wind screen on our 911s is not straightforward.
search here and you will see some really scary stories. If you get it replaced, make sure you use someone who knows what they are doing. This is not a run of the mill job.
T Silnner (04-09-2023)
8KaboveMSL (04-09-2023)
There are countless options when it comes to replacement auto glass ... I would at the very least use an outfit that specializes in German car window replacement and ask them what brands they carry. My glass guy carries about 8 different brands based on cost and quality including four OEM equivalents two of which are made by the same OEM as the original. Just make sure you are clear with your glass guy as to what you want and the glass you will receive. My glass guy is mobile so I always get to see the glass prior to installation not to mention a good glass guy can do a windshield properly in less than an hour. Because of the business I am in I use glass installers all the time and some installers will also try to cheap out by not using 3m adhesive because it's much cheaper and this can significantly affect the quality of the install.
I don't think you as the consumer can buy directly from them, but a glass shop can that has an account with them or a distributor that sells the glass.
My recommendation though would be to spend less than the Genuine (with the Porsche logo), but more than the brand you originally mentioned. The brand you're talking about is an aftermarket part that is probably not made to the same standard as the OEM glass.
Thank you, RR1 and Bxstr, very much appreciated. I’m glad I posted here, would have been operating in the dark. The fellow that runs the glass shop nearby is very fussy and well experienced, will have a good talk with him, start there. Again, thank you both!
mike cap (01-30-2024)
2009 C2S 188K miles
I have very poor experience with non-original/OEM glass. The biggest issue is a wavy field of view... wow, is that irritating. By law, the glass will be safe... but quality is another issue. I will never install glass that is not original. Further, I will only use a dealer to do the installation as again, I've had poor installation work done by Safelite... a few times. Even had an issue with a dealer install, but they made it right, and with OEM glass. These lessons I've learned a few times over.
Peace
Bruce in Philly (now Atlanta)
Peace
Yes, pop for OE or the manufacture of the OE. I would not let Safelight touch my car. The cheep glass they use pays for the millions of dollars they spend on advertising each year.
In addition to all of the good advice mentioned above I would also avoid driving that car for at least eight hours after the instillation.
Peace
Ob917 (04-10-2023)
Good morning & I’m in Canada and the quote I received from Porsche is, in my opinion, absurd: $1750 + tax for the windscreen and $420 + tax for the cowl, without any mention of labour. We have Speedy Auto Glass and they provide a chinese substitute for $620, installed, but, I won’t go this option. Does anyone here know how I might be able to source an OEM windscreen outside the dealer? Thanks,
John
John
John
John
