I have a 09 997.2 C4S Cab, I’m not too sure which lights I have but they’re stock. Are there any simple
bulb upgrade to go fro the crappy halogen/yellow ones I have to something better?
TIA
Thought about something like this for our 2009 Cayenne. Our 997 has xenon headlights. I did replace our 997 Fog lamps with LED from same company, works well.
Look on your options sheet, or call your dealer and have him look it up. You need to know if you have bixenon. If you do, you already have a ballast for the bixenon bulbs. Then you can change the bulb to a different or brighter bulb. It will make a little difference.
If you have halogen, then you buy a conversion kit with a ballast in it and convert to the brighter bixenon. Then you will see a bigger difference.
And you can match the side markers to the headlite and the already led running lites. They will all match better.
