Transmission question
Hello everyone. I have a question regarding my manual transmission. I bought the car a couple months ago when the weather was a little warmer. The car was just shy of 25K on the odometer. I have all service records and there's no history of this problem nor a transmission fluid change. When I first drove it I noticed a slight resistance getting in first gear when first started. Once temperatures were up everything felt better.
The car is stored in my garage but it's not climate controlled however probably doesn't get below 50 degrees Fahrenheit. Last night was our coldest night so far since I've purchased the car. I backed out of the garage and it didn't feel like it wanted to go into first gear so I started in second. After about 100 feet I stopped and was able to shift to first then. Resistance was still felt but it gradually improved over the next 20 miles.
The issue is definitely related to temperature but the question is whether it's the fluid or the shift cable/linkage? I never feel resistance in any other gear other than first.
I don't use the car as a daily driver and have only driven it about 600 miles since purchasing it.
Thanks for any feedback.
There are a few threads about this topic because this is a common problem. If i were you, i would start with a change of the oil in the gearbox with the genuine oil or an identical specification. This is early for the mileage, but it won't do any harm and could helb (a bit). I changed from 75W-140 to 75W90, but the same problem persists. I don't know of a real solution. When the gearbox is cold, just shift carefully and without pressure.
The gearbox is from AISIN and is not for overhaul, but there are the shafts as complete spare parts.
srb1194 (11-18-2022)
I'll do some research and see if I can find those threads. From what I know about oil viscosity I believe the lower number represents viscosity at low temperatures and the high number represents the viscosity at higher temperatures. It would seem to me that the 75 value would have to be lower to help in colder climates.
Thanks for your input.
Normal to be a bit balky into first and on the first to second shift when things are cold. Change the gearbox fluid using only MobilLube PTX which should improve things some, but won't fully eliminate it.
Sometimes helps going into first if you pop it into 2nd to stop the shafts from spinning and then go to first. Also helps to go into 1st before shifting to reverse and make sure you're fully stopped.
When things are cold, be gentle but deliberate with the shifter movement.
2009 C2S 185K miles
What Petza said.... I have dealt with this issue for many years now. Fairly common I believe. It will continually get worse if you don't address it now.
Read more here: https://rennlist.com/forums/997-foru...-gear-oil.html
Peace
Bruce in Philly (now Atlanta)
Peace
Tons of great answers and I'm not surprised by that. Thanks everyone. My feelings were that it was the oil since I noticed a change after the colder weather. I'll get the recommended fluid and get it taken care of. Thanks again everyone.
FWIW ...
It has been stated in posts here that 3 liters doesn't fully fill the box but is close enough. I did this on one friend's car and he still had difficult shifting. A few weeks later I had some spare oil after doing another friend's car with 4 quarts (leaving a half quart on my shelf). I had the first friend come back and we fully filled his transmission. His shifting problems were then solved.
FWIW ...
Peace
Damn. I stated quarts but should have written liters. Bruce, thanks for waking me up!!!
Yea Wayne, get with it... we here on Rennlist have exacting standards. Our neurotic paranoia... or is it paranoid neurosis....can not take a -.054 difference (or is it +.056). (Now will someone with an English degree please correct my grammar... I can't stand it!!!! I need to read more James Joyce)
Peace
Peace
FlatHat (11-18-2022)
To the Original Poster, the feeling of "bulkiness " in shifting when cold in the lowest gears is a result of 1) operator training (Yeah you), 2)cold lubricant; 3) the superb triple synchros (lowest gears ) not allowing gear grinding. What everybody said above is true, but in time you will adapt to the shifting exercise and most if not all of the issue will go away. I have driven stick shift cars for decades and it took me a couple of months and several thousand miles and everything got better. Changing the gear oil (PTX) after 60 to 80,000 miles makes it much better but only after you have adapted to the system.
For the more complicated sidelight of paranoia, 3 L of gear oil is plenty as the system works on the simple "splash and Hope" principle of lubrication whereas the quantity is not that critical as long as it forms the oil film and mist and heat transfer to the case.
So reading more James Joyce will help with the "Hope" part.
Rest assured I will refresh this post once I get the service performed. With the holidays it may be a couple weeks until I can get it done but I'll be back. Again, thanks for your input.
BillB128 (11-18-2022)
I think you misunderstood what Floyd is telling you. You may have driven manual transmissions but you don't have experience with these gear boxes. Everyone is telling you it's normal to be balky when cold. I have 21k miles on my box and it doesn't like being cold. When warm, it's butter. Just the nature of them.
Floyd is telling you, once you learn the idiosyncrasies of these boxes, and how to shift them, especially when cold, you will be fine. I wouldn't expect a dramatic difference after changing the fluid. I would have changed my gear oil already if I thought it would make a difference, but it won't.
I simply follow the advice given by all those above, and it shifts just fine.
YMMV.
Ps, make sure you use the Mobilube PTX, it may help. Use anything else and you WILL make it worse.
YMMV.
