Bore scoring question
Old Oct 1, 2022 | 03:01 PM
  #31
silver_tt's Avatar
silver_tt
Originally Posted by Carreralicious
Actually, if you do some googling, there’s several threads on bore scoring for a lot of cars other than Porsches (eg. Ford, Alfas, Vettes, BMWs, Hyundai, and others). It’s just that they don’t call it bore scoring…it’s under terms like cylinder scoring instead. This is not something that happens only to M96/97 or 9a1 engines. The difference is that when it happens to a Porsche, the repair options are extremely expensive compared to other marques and hence we freak out about it. If there were $15K repair options out there (like in the UK) instead of $35-40K like here in the US, it would not be such a big deal. Also, I have read about others with this problem in other makes of cars that just keep on driving them and adding oil when needed and the cars end up lasting way over 100K miles so they’re not as concerned about a few vertical scuff lines in the cylinder liners as we all seem to be. LOL.
Oh, and I have an Audi A4 daily driver that burns a qt of oil every thousand miles since new and has soot filled tailpipes. Never scoped the engine but wouldn’t be surprised if it did have scoring. Now at 78K miles and don’t care even if it did to be honest as it still drives fine.
FWIW your audi is burning oil because of the piston rings. It has a cast iron block and laser etching on the cylinder walls. It won’t score….unless you don’t put oil in it or foreign debris is introduced (seen a spark plug tip break off and do this but it was likely a fake/aftermarket plug). It won’t score from normal use like Alusil cast in place cylinders will…
