Please help with wrench stuck on bolt in tensioner pulley arm.
During my attempt to replace the tensioner pulley on my 997.1 C2S I managed to royally screw up a simple job, and use the clothes and of the ranch rather than the open end. I am unable to remove the bolt and the wrench from the tensioner, pulley arm, now.
Someone for the love of God, please provide guidance. Thank you to any and all!
Remove the alternator. Remove the oil fill tube (most likely to break it at the accordion end).
Remove the M5 allen bolt holding that little arm to the tensioner spring assembly from the back of the tensioner assembly.
Pry the right angle arm toward the back of the car until there is enough room for the wrench to fall out
On second thought, take the arm out altogether and have the 15mm bolt welded to the back of that right angle arm so you never have to use the wrench again.
Invent another name for the basterd engineer who designed that abomination.
tapcon (09-15-2022)
2009 C2S 183K miles
Another way... take and Dremel and cut the wrench. I had the same thing happen to me on a different bolt. I was using a wratcheting wrench but it did not have a switch, you are supposed to flip the wrench. Well... can't flip it if you can't remove it. Out came the Dremel.
Peace
Bruce in Philly (now Atlanta)
Peace
The following 4 users liked this post by Bruce In Philly:
I would first try to pull the bolt forward and out of the closed end of the wrench. Put a nut on it and screw it all the way to the bottom to pull the nut forward and out of the wrench. Then the wrench should be free enough to reverse the way you put it on at the start.
2009 C2S 183K miles
Peace
Peace
anewman (09-15-2022)
Not entirely true. He put the wrench on while the arm was in a position with a lot of room in the back. Once he got the belt off, the arm pivots to a position where there is no room to remove the wrench, except by brute force. I really despise that design by the way. I don't see why there is the need for that bolt to be installed in the reverse position like that.
Summerjack (09-15-2022)
