Question for those that did a CarPlay box install
Finishing the NM unit install and the space / fit behind the ac controls makes the cables really stressed, especially the blue coax on the NM box. If you’ve done this, where did you put the car play box? Suggestions welcome.
I put my 9xx unit on the hump to the right of the gas pedal ... 2010 C4S. The cables exited the left side of the PCM carriage. It was a tight fit for the box.
When we installed an NM unit on a friend's GTS his carpet was thicker and the unit would not squeeze in there. So we routed the cables out the right side of the PCM carriage and removed the thin rubbery cover under the glove box, squeezing the NM box in there.
myw (08-23-2022)
Just laid it in. It nests nicely without rattling. Routed the cables in through the top of the area.
myw (08-23-2022)
That's where my 9xx unit sits. The GTS had thicker carpet and I couldn't squeeze the NM box into the same space, so we used near to the floor below the glove box instead.
It really doesn't matter where it goes as long as it fits and is secure.
Thanks everyone! I’ll use one of these options and get it done. I’m so close to success!
I made another thread asking about two connectors I noticed behind the lower controls of the center stack. One is a purple coax antenna of some kind and the other is a small 4 or 5 pin black connection. I don’t recall disconnecting these when I removed the console. Any ideas what they go to?
