2006 997 c4 cab purchase - any help appreciated!
40k miles, 6m, clean carfax.
PPI going well so far, planning to request a scope of the cylinders next.
See below DME report.
Any concerns?
Thanks!Vehicle Model Type: 997 CARRERA 4 CABRIOLET 6 speed manual
DME Information
022 025 029 049 098 130 196 199 218 219 268 270
288 335 342 375 376 407 424 434 436 440 446 454 465 476 480 484 533 535 551 553 555 560 567 571 573 575 601 607 615 621 640 659 660 661 664 665 670 680 685 689 706 912 937 983
8014 POSIP LIN: No communication
8007 Gateway incorrect coding
8005 Terminal S
8004 Terminal 50
C152 Communication PSM control module
8035 Left seat heater
8036 Right seat heater
C174 Fault, convertible top control module
C127 Communication front control module
Any concerns?
Thanks!
Vehicle Model Year: 2006
Production Plant: Stuttgart
Number of Modules with Faults:8
DME Information
M numbers
022 025 029 049 098 130 196 199 218 219 268 270 288 335 342 375 376 407 424 434 436 440 446 454 465 476 480 484 533 535 551 553 555 560 567 571 573 575 601 607 615 621 640 659 660 661 664 665 670 680 685 689 706 912 937 983
Exclusive numbers
XRP XSCZ numbers
Country coding
, c2Ignition Ranges
Number of ignitions in range 1 : 2141 Number of ignitions in range 2 : 256 Number of ignitions in range 3 : 21 Number of ignitions in range 4 : 0 Number of ignitions in range 5 : 0 Number of ignitions in range 6 : 0 Some DME variants do not store ignition ranges.Operating hours counter
1318.800 hoursTotal distance displayed
65366 KmDME 6302
PART NUMBER(S): 99761861406
VEHICLE IDENTIFICATION NUMBER FROM CONTROL UNIT:
No faults
TIPTRONIC/PDK
Module not fitted or not communicating
PDK LEVER
PASM
PSM 0103
PART NUMBER(S): 99761813928
No faults
PTM
RDK (TPM)
AIR CONDITIONING 0201
PART NUMBER(S): 99765311111
No faults
AWS 0101
PART NUMBER(S): 99761823304
1 Fault(s) Present8014 POSIP LIN: No communication
CHRONOMETER 0102
PART NUMBER(S):
No faults
GATEWAY 0100
PART NUMBER(S): 99761010703
1 Fault(s) Present8007 Gateway incorrect coding
INSTRUMENT CLUSTER 120A
PART NUMBER(S): 99764110320
No faults
PARK ASSISTANT
PORSCHE ACCESS SYSTEM 0103
PART NUMBER(S): 99761817212
2 Fault(s) Present8005 Terminal S
8004 Terminal 50
POSIP/AIRBAG 5004
PART NUMBER(S): 99761821908
1 Fault(s) PresentC152 Communication PSM control module
SEAT MEMORY
STEERING COLUMN SWITCH 0100
PART NUMBER(S): 99761305504
No faults
VEHICLE ELECTRICAL SYSTEM 0101
PART NUMBER(S): 99761010205
2 Fault(s) Present8035 Left seat heater
CORNERING LIGHT
CONVERTIBLE TOP 0102
PART NUMBER(S): 99761811103
No faults
TARGA TOP
PASSENGER DOOR 5001
PART NUMBER(S): 99762418203
1 Fault(s) PresentC174 Fault, convertible top control module
DRIVER DOOR 5001
PART NUMBER(S): 99762418103
FRONT 0102
PART NUMBER(S): 99761010509
No faults
REAR 0200
PART NUMBER(S): 99761826006
1 Fault(s) PresentC127 Communication front control module
ACTIVE ENGINE MOUNT
Diagnostic Report compiled by Autologic Diagnostics
Nothing wrong with those ignition ranges.
Looks good .... When was the last service completed any preventitive work done I.e water pump etc ? Otherwise looks good ....
In my experience, Water Pump, Thermostat & Belts would probably be done at about 60--70K miles - Idelr Pulleys should also be done at that point becuase most need changing around 85K-90K miles.
Same holds true with engine mounts at about 60-70K miles
*Also good idea to change the front Differential Fluid and Transmission Fluid at about 70-80K miles
Nice to have the Sports Seats and Atlas Grey looks great and not a common color.
Look forward to the Bore Scope results
This is an actually stupid question I'm sure -- but in a C2 is there differential fluid to change? 997.1 C2?
groovzilla (08-23-2022)
The following 2 users liked this post by groovzilla:
C2-996 (08-24-2022),
harlanmott3 (08-24-2022)
Completely agree with that statement- definitely get it scoped.
Few other items to make sure that are functioning well at that 50-70k mileage range would be the AOS, clutch and flywheel on the 6speed manual cars.
Injectors are the other debatable item as related to bore scoring and poor spray patterns after age and mileage.
Changed them on my 996.1, curious if there’s been many who have replaced them on the 997.1 cars?
Hope adding these few other points can help with your purchase. Best of luck!!
The following 2 users liked this post by carguy999:
groovzilla (08-24-2022)
