p1675 engine purge fan - 997.2 2011
Hello friends
I would appreciate the help. I did a fault scan and the code p1675 engine purge fan appeared.
I noticed that after driving in a hot high temperature the fan spins (works) but the fan lamp, in the engine compartment, is not lit. I hope it's just a fuse. Has anyone encountered a problem and knows how to direct me what exactly I need to do? I found all kinds of things but not precisely regarding the 997.2.
Many thanks in advance
Hello friends
Did you ever figure out this issue? Found p1675 today, But fan still turns on and is working. I need to check the fuses, it’s too damn hot to crawl around in my car haha
The bulb? For the deck lid?
Bulb is lit. The deck lid latching mechanism can trigger p1675?
I’m trying to diagnose the p1675 code the OP had, though his fan was spinning. I know I’ve seen in past threads it could be a blown fuse. Wondering what the OP discovered and the solution he found.
Just checked fuses in rear. No blown fuses.
