Not trying to hijack the thread, but when you get new sensors and install them into the wheels, do you have to program the serial numbers to the car? Or do you just tell the system to relearn the TPMs and it happens automatically?
I don't think you need to program with PIWIS, had mine installed at Indy shop. If you try without be sure to write down all the numbers on them so you can get it fixed later if it doesn't work.
Did the same for my 2009 C2 about a year ago when I purchased new tires. Although my car only had ~25K miles on the odometer, I figured that because of age it seemed like the right thing do.
I bought mine from these folks and they easily synchronized after driving just a few miles. Also, at $132 for a full set, it was hard to pass up. BTW, they're made by HUF which Porsche resells with their logo at almost 4X the price.
I will follow everyones advice and change the Sensors.
Thanks for the link, but I noticed the sensors that are are $32 each are for the 997.2 turbo. The Non-turbo are listed for $70 each. Do the Turbo work on the non-turbo?
Discount Tire was quoting me $60 each, but I would rather get the HUF brand.
I don’t have TMPS in my 06, but I wish I did. I might pick up a set of the Huf’s if it doesn’t require a dealer visit to get them going. Could it be done with a Foxwell or something?
I dont have TMPS in my 06, but I wish I did. I might pick up a set of the Hufs if it doesnt require a dealer visit to get them going. Could it be done with a Foxwell or something?
You also need the receiver on the car. Since you dont have TPMS, I doubt you have the receiver and associated wiring.
There shouldn't be problem since both the Turbo and Non-Turbo sensors shown are the same frequency (433MHz) and even the same Porsche part number. However and if to want to play it safe and still get a great price try these: https://www.tpmsbargains.com/Huf-Int...m-0912-911.htm
On 997.2... with the correct sensors no need to do anything.
There are two different Huf options via tpmsdirect.com. No clue what the differences are nor which ones are the ones installed from the factory. Any insight from those that have previous experience?
I just went through this exercise. From what I can figure, the IntelliSens sensors are universal parts that get programmed by the vendor (or end user). The other sensors are programmed at the factory. The IntelliSens units allow tire stores, repair shops, etc. to stock one part that then gets programmed to its application. I purchased the IntelliSens units and TPMSdirect programmed them for my application. Caveat - I haven't installed them yet but I expect them to work fine.
Gotcha . From what I have seen online the black sensors are more like the factory units.
For the 997.2 you need not program anything! Just install, drive away and within a couple of miles they will automatically synchronize with the car's TPMS.
BTW, your so called "factory units" are not since Porsche does not make these sensors. The only thing Porsche does at the factory is install them and that's even questionable since I'm sure that the wheels and tires are supplied by an outside source and Huf seems to be their vendor/supplier for the sensors.
