Clutch Question
OK, so talked to my indy this morning. His best guess is that the clutch was abused a bit by the prior owner and most likely the problem is in the flywheel. That surprised me a bit since I was figuring pressure plate more than anything. He is generally reliable as his shop is almost exclusively Porsches and he has seen it all over the years. Also, as I explained to him, I would describe the pedal pressure as firm, definitely stiffer than my 996 with a new clutch, but I wouldn't call it hard. The problem with this job is that barring something on the outside, such as the slave, the only way to know is to actually look at it.
