Perhaps 3 weeks ago during a spirited drive I got a "System Fault - Airbag" light/message. My Indy took a look today while addressing some other issues and said they tried to clear the code (C141) and it kept re-appearing. He said It was related to my aftermarket stereo and not communicating with the PCM. Problem is the stereo was installed 2 weeks ago - after I got the airbag light. Indy advised taking it to dealer or to the car stereo place even after i clarified this.
Is a dealer with PIWIS my option here? Not satisfied with the answer from my Indy. I saw a renntech thread about Durametic not being able to clear this code because of a "handoff" but don't know if this is the same?
I had a similar issue on my 997.1 and after diagnosing and pulling the code I isolated it to the head airbag on the drivers side. I had to disassemble the door panel and found that the connector had become loose at some point. I un plugged and plugged the airbag connector, reset the code and it was gone after that.
