One new rear tire = squirrelly acceleration?
Hi fellas, I just bought new rear tires 3 months ago and they were great. Handling and balance were fine. Then, last week I pick up a nail in my driver side rear on the inner sidewall and so had to get a new tire again. In the 3 months, I only put on about a thousand miles so figured the difference in tread between the two tires would not be much. However, after the new tire was put on, when accelerating, I notice the car was a bit squirrelly so I couldn’t even fully accelerate for fear of the back coming around. Is this cause the one new tire needs to break in?
My guess is the slightly different diameters are throwing it off.
The following 7 users liked this post by CAVU:
997.2GTS (01-12-2022),
BucketList (01-12-2022),
Carreralicious (01-12-2022),
heavysixer22 (01-13-2022),
maplefrm (01-12-2022),
and 2 others liked this post.
The following 3 users liked this post by 4Driver4:
Thanks guys. I will wait a few hundred miles. The tire is exactly the same brand, model, and size as the other side so hopefully it settles.
It's just the mold release. You'll be fine.
The following 2 users liked this post by Petza914:
Carreralicious (01-13-2022),
Coolwnc (01-13-2022)
Thanks…I have about 1000 miles on the tire on the opposing side and the new tire is brand new with no miles…now about 15 miles as I took it for a drive yesterday. I checked the tread depth of both with a penny and it looked virtually the same depth.
All tires need to wear-in to scrub off the mold release on them. New tires are slippery and need to be driven gently. You're really noticing it, of course, because your new, slippery, tire is sharing the load with a grippy tire.
Just go easy for a while
It has been my experience that rear tires suffer more nail punctures than the fronts. My guess is the fronts lift the nail off the ground enough thus increasing the odds of a penetration.
The following 2 users liked this post by CAVU:
Wayne Smith (01-14-2022)
