Bigger rotors for my C2.
Firstly really like the mods you have carried out on your car and also the solutions you provided to fellow Porsche owners. I have read your post about changing your standard 997.2 3.6 carrera 2 closed caliper design to the 997.1 3.8 Carrera S open caliper which makes it much easier to swap out pads
In that post I believe you stated that the 997.1s uprights are the same for 997.2 c2 and 997.2 c2s.
Are our uprights different to 997.2s? Reason I ask is that I’ve found some 997.2s calipers- will these fit on our uprights as well? If not they can also supply 997.1s calipers but they are not in the best condition cosmetically so will need to be refurbed. Just to confirm - Did the 997.1s caliper bolt directly upto the 997.2 c2 upright without any adaptors or offset issues?
I have been researching for quite some time but thought I’d seek your invaluable experience and assistance on this as you have successfully carried out the caliper swap.
thanks
thanks
