noise diagnosis - high pitched squeal with ignition ON prior to cold start
Hi all, I apologize for not having that much to go on. I have only had my first Porsche for a couple weeks now, and it's emitting a sound I don't recognize that I don't think is normal. It is a 2006 C4S cab with about 118k miles. It's a high pitched squeal. It happens most (but not all of the time), at first I thought it was when I turned on the engine, but I found that when I just turn the key to the on position (e.g. to get the oil level reading in dash) it does it then too. It only lasts for less than a second but it's noticeable. I haven't yet had someone cause it while I was outside the vehicle to try and localize or record it. Does this sound at all familiar, or anyone with suggestions with what to look for? I will probably be setting up its 120k service sometime in the next few weeks and I could ask them to identify/diagnose but thought I'd ask here first. Thank you.
Maybe the fuel pump primes with key on prior to starting. Does it sound like a brief buzzing for a couple seconds as that would be normal for a fuel pump prime. At your mileage, it's possible the pump may be going bad as well, but we don't see a lot of fuel pump replacements on the non-DFI cars.
I have a 2006 S that just started doing the same thing. When I keep the ignition to start the car a high-pitched squeal is emitted from the frunk area, seemingly near the windshield. It's only noticeable when I key the ignition to engage the starter. It's very loud and quite noticable.
I surely will. I'm hoping someone else on the forum has experienced this issue. I find it quite annoying that my car making this horrible noise, not to mention it doesn't sound like whatever's making the noise will cure itself.
I turned off the radio and shut down the auto HVAC. When I keyed the car it made no noise like what I was experiencing. So i turned everything back on, shut the car off, gave it a minute and started it again. No noise this time either. I'm going to let it sit overnight and try it again in the morning.
Here is a video for your listening pleasure.
https://youtu.be/9N8UWBxqKb8
No idea what that is, but it's not right.
You could try pulling fuses one at a time, see if it makes a difference (obviously don't try to start the car with the fuse pulled).
[Edit: crap, that's the 987 fuse diagram, lemme see if I can find the 997 one]
Okay, 997 fuses here: https://rennlist.com/how-tos/a/porsc...diagram-376033
D1 is the fuel pump, D5 looks like the DMTL pump and tank stuff, and D9 is the CD/DVD/Nav stuff
