Bleed ABS when replacing master
Old Nov 20, 2021 | 10:45 AM
dgjks6's Avatar
dgjks6
Default Bleed ABS when replacing master
Today doing the master cylinder. Do I need to bleed the ABS after or can I just do the standard motive power bleed?
Old Nov 21, 2021 | 08:35 AM
Petza914's Avatar
Petza914
Standard should do it. If you can't achieve a hard pedal, then move on to the abs pump and circuits. May want to bleed the clutch slave while you're at it if you have a 997.1 (997.2 clutch slave self-bleeds).
Old Nov 21, 2021 | 11:06 AM
dgjks6's Avatar
dgjks6
Thanks. No clutch.
I replaced the master yesterday. Took 15 minutes. Then started on the R rear. 2009. 54K miles. Original rear pads and rotors. The inside of the right rear the pad was stuck on the big slides so only part of the pad was contacting.
I wonder if this was my problem? Guess we will never know.
